Builds are interrupted after logging out of build machine
emddudley
My Bamboo server runs on Windows XP (32-bit), and sometimes I use Remote Desktop to administer it. If I log out of the machine while a build is running on the local agent, the build gets interrupted. Any way to prevent this from happening?
Bob Swift
May 8, 2012
We configure our bamboo service to run as a specific user (not the default local system) and this helps with a number of problems running on Windows. Specifically, we don't have the issue you describe at least on Windows Server.
