Hi to all. I have an unexpected problem after git push to my pull-request.
I have installed mysqlclient ins step: - pip install -r $BITBUCKET_CLONE_DIR/requirements.txt!
On step - python manage.py makemigrations I got next error:
django.core.exceptions.ImproperlyConfigured: Error loading MySQLdb module: libmariadbclient.so.18: cannot open shared object file: No such file or directory.
Did you install mysqlclient or MySQL-python?
my bitbucket.pipeline file
image: python:3.6
pipelines:
pull-requests:
- step:
caches:
- pip
script:
- export DJANGO_SETTINGS_MODULE=myproject.settings.tests
- cd $BITBUCKET_CLONE_DIR/src
- flake8
- python manage.py migrate
- coverage run --source='.' manage.py test
- coverage report -m
services:
- mysql
- mongo
- redis
definitions:
services:
mysql:
image: mysql:5.7
environment:
MYSQL_DATABASE: my_db
MYSQL_ROOT_PASSWORD: root
mongo:
image: mongo
redis:
image: redis
Everything works fine on my local computer!
Can someone help me with this problem?
Could you upload logs from the pipeline to help with debugging it?
The error is not pipeline specific and I would make sure first that you can run above steps with the same docker image in your local environment. This is a reference that I found that may be helpful: https://stackoverflow.com/questions/34348752/error-loading-mysqldb-module-libmysqlclient-so-20-cannot-open-shared-object-fi
Peter
