Hi there!
I'm new to Jira Development and I'm a bit confused on how can I manage Jira issues programmatically.
My goal is to create a windows application (prefferably using microsoft tools -C#/VB.NET etc-) with the functionality of creating and editing a Jira issue.
I've searched for possible solutions but couldn't find something suitable to my requirements.
So if there is any link for guides or tutorials regarding issue management through code, I would appreciate it if you could let me know..
Thanks in advance
George
As far as I undertand about using SOAP using Visual Studio C# (with any version for that matter), do an auto generation of code by importing the WSDL from your local jira or even one of the publich JIRA instances (same version) and directly using the generated classes. I have no clue about atlassian.jira.dll, I have not used it.
And if you business logic requires that you trigger JIRA, then SOAP or REST is fine. But if you need JIRA to trigger you, either you should write a plugin, or use the latest method of Webhooks (in labs) which can trigger you via JSON data during issue changes.
And regarding, when/how you write a plugin, read https://developer.atlassian.com/display/HOME/Welcome
Renjith,
What do you mean by "do an auto generation of code by importing the WSDL from your local jira or even one of the publich JIRA instances (same version) and directly using the generated classes." How can I do that?
Regards
Praveen.
Praveen, check http://lmgtfy.com/?q=access+a+web+service+visual+studio+wsdl
VB.Net methods (Don't forget that JIRA is a case sensitive instance and the JIRA issue key MUST be upper cased when using methods)
This should get you started
'JIRA specific variables
Private JiraSoapService As New JiraSoapServiceService
Public JIRA_token As String = ""
Public JIRA_userName As String = ""
Public JIRA_password As String = ""
Public JIRA_status As String = ""
Public JIRA_key As String = ""
Private Const JIRA_ProjectStr = "TECH"
'JIRA specific functions and Subs
'Connect & login
Sub JIRA_Connect()
JIRA_token = JiraSoapService.login(JIRA_userName, JIRA_password)
End Sub
'LOGOUT
Sub JiraLogout(ByVal JIRA_userName As String)
Try
JiraSoapService.logout(JIRA_userName)
Catch ex As Exception
'Nothing to do if there is an error.
'Maybe the user is already disconnected because of the session timeout.
End Try
End Sub
'Return a JIRA issue by ID
Function JIRA_getIssue(ByVal issueKey As String)
Dim theJiraIssue As RemoteIssue
Dim theJiraProject As RemoteProject
Dim remoteUser As RemoteUser = JiraSoapService.getUser(JIRA_token, JIRA_userName.ToLower())
If Trim(remoteUser.name) <> "" Then
'Set the JIRA project type
theJiraProject = JiraSoapService.getProjectByKey(JIRA_token, "TECH")
'Get the Issue structure
theJiraIssue = JiraSoapService.getIssue(JIRA_token, issueKey.ToUpper)
JIRA_key = theJiraIssue.key
'Set the status string
For Each remoteStatus As RemoteStatus In JiraSoapService.getStatuses(JIRA_token)
If remoteStatus.id = theJiraIssue.status Then
JIRA_status = remoteStatus.name
End If
Next
Return theJiraIssue
Else : Return vbNull
End If
End Function
Here's a method for adding a comment:
Private Sub butSave_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butSave.Click
Dim theComment As New RemoteComment
Try
theComment.author = theUser
theComment.body = tbComment.Text
theComment.created = Date.Now
JIRA_setIssueComment(theComment)
theSubmitResult = 1
Me.DialogResult = DialogResult.OK
MsgBox(ex.Message, , "Error saving comment")
theSubmitResult = 3
Me.DialogResult = DialogResult.Abort
End Try
End Sub
'Add comment to JIRA issue
Sub JIRA_setIssueComment(ByVal theComment As RemoteComment)
JiraSoapService.addComment(JIRA_token, JIRA_key, theComment)
End Sub
Interacting with the JIRA SOAP services via C# is pretty straight-forward. The one important "trick for beginners" to note is that the WSDL file generated by JIRA is incompatible with the .NET WCF Client in .NET 3.0 and greater. To successfully generate client classes for .NET you need to use the older .NET 2.0 wsdl generator (in Visual Studio that's a "Web Reference" rather than a "Service Reference", or using the command line wsdl.exe tool).
For a leg-up on building out the client classes, have a look at https://bitbucket.org/farmas/atlassian.net-sdk/wiki/Home and https://bitbucket.org/MikeJansen/jirarestclient.net/wiki/Home
thanks for your reply Joseph
i'll checkout the links you posted (and probably return with more questions :) )
George
In addition to the .NET SDK that Joseph mentions above, you might also find this useful: https://bitbucket.org/farmas/jiratrayapp. It is a windows tray application to create JIRA issues (written in C#).
- Federico
Checkout https://developer.atlassian.com/display/JIRADEV/JIRA+RPC+Services
REST is the preferred way as it is improving lot in the later/upcoming versions. JIRA 5.0 has big improvements with REST.
REST is not supported for creat/update/delete in 4.1. You might want to look at SOAP.
Yes, but it's not as advanced as Jira 5.0.
i forgot to mention that in my company we use Jira v4.1
Is REST applicable to this version?
Thanks for your reply
As i can see soap will be the right way to implement my application....
Does anyone know if there are any examples of using soap services within c# or VB.NET?
Hi Jordan,
Thanks for your reply. But could you be more expalanative. Also, please mention any reference materials for the same.
Regards
Praveen.
REST is not supported as a platform but you still can create your own APIs and deploy it.
I'm not familiar with Visual Studio, but I suspect reading the docs for it will get you a much faster answer than hoping that someone here knows VS well enough to walk you through it, spots your comment and takes the time to answer.
You can create the REST api required what you think will do the job and the REST API can be called from any client. It is reqular as any other plugin.
Praveen, I hope you read the comment from Joseph Clark below.
I am breaking out this to a new answer below.
Hi Renjith,
Thanking you first. I've written a code snipped similar to the one mentioned in https://bitbucket.org/MikeJansen/jirarestclient.net/src/f77556b2be7e/JiraRestClient.Test/JiraRestClientTest.cs
But as I've written this code in VSTA which supports .NET 2.0 framework, the issue arised. The Atlassian.Jira.dll provided by JIRA is of version 4.0.
So, I had to rule out this opiton. I don't know if I'll have to use a plugin to interact with my project. In that case will there be an issue with the version of dlls?
What is the main use of plugin?
Sorry if i'm posting too many questions.
Regards
Praveen.
