Can anyone please help me out here.
How can I made it possible in JIRA that a issue is only allowed to move if and only if the Target project which we select is same as the Project we selected in a Project Picker field in the issue ?
Unfortunately that really can’t be done if the individual performing the move has move permissions in the “from” project and create permissions in the “to” project. Maybe there is some addon for this but I have never experienced one.
So It is not possible even using a behaviour ?
Maybe if we can remove all other projects in the target project field except the required project.
I assume you are asking about using Scriptrunner Behaviour? While I do not use this addon the documentation states the following - “Behaviours will not work on the Move Issue screen.”.
