Adding Content in Jira Issue View
Ahmed Charfi March 8, 2016
i would like to get the content of TestData in an issue  and generate a file which contains the information written in column TestData. it will be similar to export world.Can anyone give me a tipp how exportworld is done or what should i do to do my task.
Thanks;
Peter T
March 10, 2016
Hi Ahmed,
this article describes the different export options and how to use them.
https://confluence.atlassian.com/jira/working-with-search-result-data-304579186.html
When you are exporting you have the option to export only the visible columns - in this case you have to make TestData visible or all columns (all fields) configured for this issue type.
Peter T
Vasiliy Zverev
March 10, 2016
Have you tried export to Excel with current columns?
You should go to issue navigator, filters requared issues. Then select requared columns and then export it to Excel.
