Hi team,
Our structure is Initiative > Epics > Tasks > sub-tasks
We are trying to get the last comment from all the epics under an Initiative, aggregate them and add them as last comment to the parent link (their Initiative):
Epic_N_1
Comment 1
Epic_N_2
Comment 2
Epic_N_3
Comment 3
Results:
Initiative_N
Comment 1
Comment 2
Comment 3
Where:
Initiative_N is the parent link of Epic_N_1 & Epic_N_2 & Epic_N_3
Is this possible?
If so, please let us know how to do it
Hello @Mohamed Tafifet ,
David from ALM Works here. Welcome to the Community!
When you say your "structure", are you referring to our product, Structure - Flexible Jira Project Management?
If so, we just recently introduced the ability to use an Attribute to Issue Field Effector to add a comment (8.1.1). You would want to use a formula like ARRAY#children{last_comment} as your attribute.
Looking forward to your feedback!
Best,
David
Hi @Mohamed Tafifet ,
If you have the app Jira Misc Workflow Extensions or ScriptRunner you can achieve this.
With JMWE you can create an event-based action.
I've added the "(" + issue.get("issuekey") + ") " + part so that it also posts the issue key of the Epic on which the Comment was posted.
@Rik de Valk thanks for the answer, unfortunately we don't have those extensions in the company, but thanks for the support
