Can't find Create Issue tap
hyeslee
November 27, 2019
It's my first access to Jira for Quote.
I can't find 'Create Issue' tap for New ticket.
There is a notification : You have not selected a valid project to create an issue in.
Amith Mathur _Appfire_
November 27, 2019
Hi @hyeslee ,
Please contact your JIRA administrator and he/she will be able to assign you the appropriate create issue permissions, if the JIRA instance has a valid license.
Amith Mathur
hyeslee
November 27, 2019
Thank you for your reply.
Unfortunately, I can't even find Create button on the top as you can see the photo below.
Could you please help me to find the button in Jira? Thanks.Jira 2.PNGJira.PNG
November 27, 2019
Hi @hyeslee ,
Welcome to Atlassian Community.
Did you clicked on Create button on the top ? If so, once you click on the Create button, you need to select the project (hopefully, project is created). You can follow the steps as mentioned in the below link and you will be able to create your first issue in JIRA.
https://confluence.atlassian.com/jiracoreserver073/creating-issues-and-sub-tasks-861257329.html
If you are still facing the issue, then please share the screenshot of the JIRA here, where you are getting the above mentioned message.
Amith Mathur
