Can't resolve issues during issue transition
Mark Ungerer
January 15, 2013
We can't resolve issues when we transition them into closed or deployed status. I looked at the following link (scroll down), but the post functions I see in a transition don't have resolve option:
https://confluence.atlassian.com/display/JIRA/Configuring+Workflow
Also, it seems these edits to transitions can only be done on a draft of the workflow? Then how do we update it so that all of our transitions to closed (there are ~10 going in) resolve this issue? This seems like it should be a super simple thing to do - maybe I am missing something!
Mark
Mizan
January 15, 2013
In your workflow there is no transition from closed/deployed to resolved . You will need to add these transition then publish the draft for the changes to take effect.
Vishnukumar Vasudevan
Question is little confusing, at least for me. I guess you need to set a value to the field ‘Resolution’ over transition, if so you can achieve this with the help of Post-function.
The available post-function is ‘Update Issue Field’.
Sorry, didn't get the second part.
John Chin
January 15, 2013
Hi Mark,
Basically, I think you should check the post function and add the function to change the resolution field to Fixed/Resolved. Then, the issue will become resolved eventually.
Yes, in draft you can edit in transition but is for temporary purpose. After confirmed every things change in workflow, you may publish it and make the workflow become permanently to be daily used.
You can use the Bulk Edit: https://confluence.atlassian.com/display/JIRA/Modifying+Multiple+%28%27Bulk%27%29+Issues
Hope it helps.
