Is there a way to store Issues in a custom field? Maybe for a special type only?
a.haaken
Are there ways to define a field, that containsa link t o another Issue?
This filed should be configurable, like, mandatory, issuetype, cardinality
Any suggestions?
Jo-Anne MacLeod
April 11, 2012
Have you tried to create a cutom field of type "url"? then just enter the link to your issue in there.
Dieter
April 11, 2012
This is not a direct answer to your question but please also consider if linking your issues might not be achieved by tagging them using a label custom field. In all custom field based solutions you can restrict linking issues of a certain type by defining an issue type specific field configuration context
Ramiro P
April 10, 2012
The only thing that I know that you could use would be the Issue Link. But it's only a link, it can't be 'configurable'.
