Jira REST API call for issue create failing
Gaurav
Hello All,
One of the scripts to create issues using REST API is giving the return code 400, with the following message:
Truncated server response: {"errorMessages":[],"errors":{"reporter":"Field 'reporter' cannot be set. It is not on the appropriate screen, or unknown."}} (use muteHttpExceptions option to examine full response)
This is after the script defines the reporter and the user credentials used to execute the script have the relevant permissions on the project. This screen scheme has also been validated, and the create screen has the 'Reporter' field.
Code segment is as below:
var data = {
    "fields": {
      "project": {
        "key""ABC"
      "issuetype": {
        "name""Story"
      "reporter": {
        "accountId":"622724d2302c6b006af51ec4"
      "summary"summary,
      "description": {
        "type""doc",
        "version":1,
        "content":[
            "type""paragraph",
            "content": [
                "text"description,
                "type""text"
The Atlassian documentation available here, mentions setting the reporter differently. This has also been tried but still gets the same error.
Has some on seen this behaviour previously?
Looking forward to hearing from community experts on how to resolve this.
Gaurav
Bob Lopez
November 17, 2022
@Gaurav did you figure this out? I'm having the same problem with the exact same error message.
Matt Doar
So this is a company-managed project in Jira Cloud?
Worth checking the field configuration doesn't have the Reporter field hidden for some odd reason
Matt Doar
And the account used may need to have the Modify Reporter permission in that project
Gaurav
Hello @Matt Doar
Yes, this is a company-managed project in Jira Cloud, a standard subscription.
The reporter field is visible on the Create Issue screen and the user (myself) does have the Modify Reporter permission in that project.
Gaurav
Chu Dam
Hi @Gaurav
like the doc you mentioned, you should use reporter > id and not reporter > accountId in your var data ;)
"reporter": { "id": "5b10a2844c20165700ede21g" },
I hope this helps.
Let us know if its solved the problem.
Dam.
Gaurav
Hello @Chu Dam
Thanks for the prompt response. As suggested, I updated the code to use 'id' but it still fails with the same error.
"issuetype": {
        "name""Story"
      "reporter": {
        "id":"622724d2302c6b006af51ec4"
I had tried this option previously as well without success. Any other suggestions to resolve this?
Gaurav
