Making an external Link and changing it in Jira is a nightmare
Johannes Haase May 22, 2025
In any Jira tickets when someone must create an external Link to any http(s) address the usability is very bad.  For example, when someone has a very long technical http(s) address this can lead to errors and is almost unmanageabel.
[Link|http://example.com]
Furthermore, this link is afterwards only under difficulties changeable.
Could you please think about to improve this in further Jira releases?
Jack Brickey
Hi @Johannes Haase , i'm not exactly sure what you are referring to as to the difficulty. Regardless, I highly recommend you use the in-app Feedback to share your thoughts with Atlassian directly. You will find this under the "?" Icon in the upper right corner. It is not as likely to get the proper attention here in the community given it is primarily monitored by users.
Thanks!
