Automation Rule for EPIC
yogyata Mehan August 1, 2023
Hi Team,
We want to create a Auomation rule in which all the subtasks, and child issues within EPIC actuals are summed up.
Thanks in advance.
Jack Brickey
Hi @yogyata Mehan , see if this article by Alex Koxaras helps. Also there are quite a few past post in the Community on this so I encourage you to use the Search bar as well.
yogyata Mehan August 3, 2023
Thanks Jack. My issue is actuals. I want to sum actuals.
Jack Brickey
Can you not reference "time spent"? Do you have a rule you are trying to get to work? If so can you share a screenshot?
