Automation in JIRA | Correct Timezone
Mareli
Hello All,
I created this automation to update the summary when a field value changes:
I have managed to get the date format the way I want it but I am struggling to set the correct time in the summary.
In the Automation the date field referees to customfield_12025 which is the "Start Date ann Time (DP)" field:
As you can see the time is set to 2:30 PM.
But when I trigger the Automation the wrong time comes up, the time reads 12:30 instead of 14:30 or 2:30 PM:
I've tried the following to get the correct time:
  1. {{issue.customfield_12025.format( "EEE, dd MMM yyyy HH:mm 'CAT'").convertToTimeZone(SAST)}}
  2. {{issue.customfield_12025.format( "EEE, dd MMM yyyy HH:mm 'SAST'").convertToTimeZone(SAST)}}
  3. {{issue.customfield_12025.format( "EEE, dd MMM yyyy HH:mm").convertToTimeZone(SAST)}}
  4. {{issue.customfield_12025.format( "EEE, dd MMM yyyy HH:mm").convertToTimeZone(CAT)}}
  5. {{issue.customfield_12025.format( "EEE, dd MMM yyyy HH:mm 'CAT'")}}
  6. {{issue.customfield_12025.format( "EEE, dd MMM yyyy HH:mm 'SAST'")}}
None of these seem to work they just leave out the date and time completely, like this:
Any advice?
3 votes
Trudy Claspill
Hello @Mareli
I have two recommendations.
First try swapping the time zone conversion and format functions. Both apply to a date/time value, but with the current order you are trying to apply timezone conversion to a formatted string. Try this order:
{{issue.customfield_12025.convertToTimeZone().format()}}
Second, I don't think the codes you are trying for time zone conversion are valid. In the documentation for the time zone conversion function...
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-date-and-time/#Convert-timezone-date---
...there is a link to a document from which you can get the valid entries to use for all the time zones.
https://joda-time.sourceforge.net/timezones.html
I don't see SAST or CAT in that list.
Mareli
Hi @Trudy Claspill
IT WORKED!
Thanks so much:
I used this one:
{{issue.customfield_12025.convertToTimeZone("UTC+02:00").format("EEE, dd MMM yyyy HH:mm")}}
Like # people like this
QASIM ALOUDAT
Banned
September 30, 2024
Hello
@QASIM ALOUDAT
I am expect the country must pay for local timezone
Marc - Devoteam
August 13, 2024
Hi @Mareli
Could you try {{issue.customfield_12025.jiraDate}}
Mareli
Hello @Marc - Devoteam
This one did not work it does not give me the time and also the format is not correct
