Can not create subtasks in Jira Advanced Roadmap
Adrien
February 4, 2022
Since the new create issue dialog box which does not propose any subtask for the issue type, Advanced Roadmap can not create subtask issues as it uses this dialog box.
Am I the only one with this issue?
Best Regards,
Adrien
Alex Koxaras -Relational-
Hi @Adrien and @Diarmuid Murphy
Currently you can create subtasks by going on the standard issue type, clicking the three dots and chooce create subtask:
Jack Brickey
I believe you would create the subtask from within the parent task/story not at the create issue level. Admittedly Advanced Roadmaps presents new behaviors which I do not use.
Adrien
February 7, 2022
The main idea is to use Advanced Roadmaps tu create subtask directly in it for planning. It allows it, it can just not create them when clicking "save selected change to Jira"
Jack Brickey
i saw something mentioned in today's rollout notice...
Create subtasks in the timeline view
ROLLING OUT
You can now break down items into smaller subtasks in your timeline view. Subtasks are smaller items that relate to the overarching objective.
siddharth.sahoo@firstapex.com
February 14, 2022
I am also facing same problem. This looks like a BUG in JIRA and they need to fix this.
Robert Horan
I too am unable to create subtasks
Diarmuid Murphy
July 19, 2022
Facing the same issue as the above users. Story is the lowest issue type that I can open directly in roadmaps.
Has anyone found a fix?
