Hi everyone and happy new year !
I'd like to set an automation that copy comment entered by customer on a portal to a linked (jira software) ticket.
As for now, I succeed in copying comment from one ticket to another, but it doesn't work when the comment is entered at customer portal level.
Does anyone have any idea ?
Thank you,
Nicolas
Without testing it on my instance my best guess is, that author.displayName doesn't work for external comments, as the "Author" is the customer and doesn't have a displayName?
Have you checked the Audit Log?
When the comment is entered in the portal, everything seems to work as expected (see logs attached), but the comment is not copied in my targetted issue
Yeah, i understand.
What I meant was the Audit log of your Automation rule: What is the automation audit log? | Cloud automation Cloud | Atlassian Support
You can see if anything failed and - if you add the "Log Action" to your automation and just put in the{{author.displayName}} - you will see in the Log what that Smartvalue returns
Sorry, I forgot to attach the right log screenshot ....
Finally I found the solution, I just had to uncheck this box ...
Aaah. Tricky :D glad you found it and thanks for letting me/us know!
