By default, JIRA should automatically copy the contents of your Comments to the Workflow Description. In doing so, the work log will be visible to members of the project role or group selected in the padlock icon dropdown.
If this is not happening and you would like comments to be copied to workflow descriptions, request that your JIRA administrator enables JIRA's Copy Comments to Workflow Descriptions setting.
If this setting is disabled:
Hi Vimala,
The work description appears under the "work log" tab.
JIRA by default copies the contents of comments to the work log tab when logging some work.
Hope this provides some explanation.
Best regards,
Lenard
Hi Marivi,
There are JQL functions related to worklogs.
For example, you can search via "worklogComment" and "worklogDate".
Best,
Lenard
