How to clear assignee using script runner custom listener
Srikanth Kola December 11, 2017
I need to clear assignee field in JIRA using script runner custom listener.
I wrote the below script to listen to field "Assigned Workgroup" when it is updated then I want to clear Assignee field
import com.atlassian.jira.ComponentManager
import java.sql.Timestamp
import groovy.time.TimeCategory
import java.time.*
def issue = event.getIssue()
def issueKey = issue.getKey()
def issueInputParameters = issue.getAssignee()
def date1 = new Timestamp(new Date().getTime())
def date2 = new Timestamp(new Date().getTime() - 5000)
def changeHistoryManager = ComponentAccessor.getChangeHistoryManager()
def change = changeHistoryManager.getChangeItemsForField(issue, "Assigned Workgroup")
String KISH = change.findAll{it.created < date1 && it.created > date2}
if (KISH == '[]'){
return null
}else{
issue.setAssignee(null)  - This line throws error saying "check if declared type is right and if the method exists"
Alexey Matveev
December 11, 2017
Try to run the script. I think it is just a static compilation error. If you run it, then it should work
Srikanth Kola December 12, 2017
Yes it did, the error was misleading. Thank you
Kumar
January 18, 2019
HI @Srikanth Kola @Alexey Matveev
I have same requirement When ever the Group Picker field is changed or updated or Empty
Then make assignee field as EMPTY (Unassigned) on issue
So i used the above script in the script listener so issue update even for me its not working
can you please help me how to make it work
Kumar
