can i clone folder on cycle to another project?
In your last screenshot you are showing test capabilities, what marketplace app are you using in Jira for test management?
If you clone a folder, I think it clones with al issues, but in the same project.
You should be able to use that in another project.
But to be sure, reach out to the vendor, via their support. They should be able to give you a definitive answer.
Welcome to community!
Can you elaborate your question?
Is this something with any specific plugin feature?
hi i want clone folder include issues to another project
example
i have project x with aa cycle and bb folder and i want to duplicate bb folder include issues to project y can i do that?
As @Fazila Ashraf asked, can you clarify.
The terms folder and cycle are no terms used in the context of Jira
