How to search stories which do not have a particular subtask ?
charutiwari November 25, 2019
I want to search all the stories which do not have a subtask with subtask summary "integration tickets" ?
Jack Nolddor _Sweet Bananas_
Sadly you must go for a third-party app for this complex query.
Using i.e. JQL Booster Pack you must type:
Find Stories not having Subtaks with summary "integration tickets"
type = Story AND issue NOT IN parentsOf('summary ~ "integration tickets" AND type in subTaskIssueTypes()')
Regards
Muhammad Ramzan(Atlassian Certified Master)
November 25, 2019
@charutiwari As mentioned by others, its not possible naively, I am using  JQL Search Extensions for Jira & reports.
I would suggest give a try , its not that much expensive and have amazing built in queries.
In your case by using this plugin following query will get all user stories which have no sub tasks.
issue in subtaskCountLessThan(1)and issuetype=story
charutiwari November 26, 2019
Thankyou @Muhammad Ramzan(Atlassian Certified Master) , is there any free version of this in the marketplace?
November 26, 2019
Unfortunately its paid one, but you can give a try at trail version , all plugins in jira are available on trail for one month
charutiwari December 2, 2019
@Muhammad Ramzan(Atlassian Certified Master) : Would I need to purchase this for every login on my cloud JIRA or just one overall? Say if it cost $10 and my cloud JIRA has 20 user, Would I need to pay $200?
If it is for every login, can I purchase it for only my login and not everyone?
Thanks!
Thankyou everyone. Is there any free extension I can get for this in the marketplace or anywhere else?
As I suggeted, JQL Booster Pack is free prior to 2.x version.
Like charutiwari likes this
@Jack Nolddor _Sweet Bananas_  would it work with Cloud JIRA?
Not sorry, only available for Server & DataCenter deployment options
Leonard Chew
November 25, 2019
Scriptrunner
type = story and issueFunction not in linkedIssuesOfAll("summary~'integration tickets' and type=sub-task")
Search Linked Issues
type = story and issue not in parentIssuesFromQuery("summary~'integration tickets'")
charutiwari December 3, 2019
@Leonard Chew  : I added scriptrunner . However the functions and query you suggested is still not available.
Like meenu_hooda likes this
Jack Brickey
OOTB you can’t find issues that have or do not have sub-tasks so that interferes with your goal. You can accomplish this using an addon like Scriptrunner and others.
Solomon David Cherian November 25, 2019
You will need to have Scriptrunner for the same. It has "issueFunction" capability in JQL that provides help complicated requirements.
