JMWE add-on Conditional execution not working
Almu October 6, 2021
Hi guys,
Jira Data Center, JMWE 6.2.4, JMCF 2.1.6
Ive got a Calculated (scripted) Number Field by JMCF -> Condition1
and I use it in the JMWE postfunction for Conditional execution:
Only if condition is true
linkedIssue.get("Condition1") > 0
Although the condition is true (Test Groovy), the Transition Related Issues Post-function does not run. It works without conditional execution.
If the condition is true , why it does not run???
Is this a bug?
Thanks a lot for your help.
David Fischer
Hi @Almu ,
it really depends on the "formula" of the Calculated (scripted) Number Field - it might not return the expected value when evaluated during the transition. You should add logging in your calculated field to log the returned value.
Hi David,
Thanks for your swift answer.
The calculated field returns:
Result type:
Integer
Result value:
1
That is why the JMWE postfunction for Conditional execution:
returns true.
So, any idea, please?
Thx a lot!
David Fischer
Do you mean that the formula is:
return 1
If not, can you try modifying the formula to just that, just to test whether that works?
Almu October 7, 2021
Hi David,
Sorry for the delay.
The problem was in the calculated field code. Although it showed:
Result type:
Integer
Result value:
1
It was not really integer 1. So I used a condition and put return 1, and it works.
Thanks a lot for your help!
