can someone help with a JQL query please?
i have an automation trigger in Jira, where i would like it to be triggered if the due date of an issue is either tomorrow or on current day at 3PM. i figured out the time part but cannot get the JQL right for the day part.
Hello Sibiya,
JQL
Tomorrow due < endOfDay("+1")
Today till 3PM due <= startOfDay(15h)
It will find all issue that is due, also it will find an issue that was due yesterday if you need specific issues that are due specifically tomorrow
Specifically tomorrow due <= endOfDay("+1") AND due > endOfDay()
Today till 3 PM due >= startOfDay() AND due <= startOfDay(15h)
BR, Olga
thank you, would it work if i want the trigger to look for any issues that has a due date of tomorrow? as in, i would be running the rule today and i want it to look for issues having a due date of tomorrow.
Yes, it will.
You can check it easily just run the JQL in your issue search and check the results.
BR, Olga
