Hi all,
On screen of a project, we have field called assignment group, when changing it the work-notes should be popup. can anyone help me with the requirement
Rajesh
Hi Rajesh,
Do you want the work-notes field to be required or to be opened like a pop-up?
The first option is possible and I can help you with, the second one, you would need to create a new screen, for it to be opened, once this happen.
Could you please indicate which one would fits you better?
Hi Senna,
I need make worknote field as mandatory.
When changing the Assigment Group. thanks for your response.
Rajesh.
