Problem while creating an issue
kondaparthy sumanth May 23, 2018
Hi
I have 2 groups , while creating a issue one group want X custom field while other group doesn't want that custom field.
        IN BRIEF:
Lets say , 2 groups be A&B, and two custom fields be X&Y
1.While creating an issue on CREATE ISSUE SCREEN  "A "group want "X" custom filed for same issue type (task) and same project, Y field shouldn't be visible
2.And for B group ,While creating an issue on CREATE ISSUE SCREEN  they want Y field on same issue type (task) on same project, X field shouldn't be visible.
Hope for the detailed steps.
Thank you.
Alexey Matveev
May 23, 2018
You would need an add-on for it like Power Scripts (Live Fields) or ScriptRunner(Behaviours)
Hi Matveev,
I'm using cloud version,  Please can you provide me the addon and script for that.
Alexey Matveev
May 23, 2018
It is not possible for Cloud. UI can not be modified in the Cloud version.
please can you give me the script for server version
Alexey Matveev
May 23, 2018
You do not need to write a script for the ScriptRunner plugin. You can find an example here:
https://scriptrunner.adaptavist.com/latest/jira/behaviours-overview.html#_example_setting_up_a_hidden_field
