Using automation to copy from a custom select field to a label
Benjamin Peikes
July 21, 2021
Is there any way using native automation to copy from a select list to a custom label list?
We have a select list "Customer Select", which restricts the set of items, but we need to copy whatever is set there to a "Label" field we created years ago called "Customer" which allows us to add multiple customers to a single issue.
Want to avoid using script runner if possible.
Deepanshu Natani
Hi @Benjamin Peikes
You can use an automation rule like the below to copy the value from "Select List Custom Field" to a label type custom field:
Benjamin Peikes
July 21, 2021
Thanks, I’ll try that. I didnt know you could use “smart” fields in the automation rules outside the json section.
Deepanshu Natani
Hey @Benjamin Peikes
You should definitely look at using smart values for automation in this way. This can be used for a lot of other things too.
Rudger de Groot
April 17, 2023
The only problem I run into is that label doesn't support values with spaces...
So this will only work for fields that have no spaces in the values...
Bill Sheboy
July 21, 2021
Hi @Benjamin Peikes
I believe you can do that with advanced field edits with JSON.  Please take a look at the examples in this documentation to try to match up with your field types for the edit:
https://support.atlassian.com/jira-software-cloud/docs/advanced-field-editing-json/
Best regards,
Benjamin Peikes
July 21, 2021
Thanks! I looked at this, and it does look like we can add a custom label field, but its not clear how to reference the select field.
For example if the select field is called “Customer Select”, how do you reference it?
I think our json would look something like
    "update": {
        "Customer": [
                "add": {{issue.customerSelect.value}}
 But I’m not sure how you reference single select value, and not sure how to reference field names with spaces in them.
Bill Sheboy
July 21, 2021
Please see the example from @Deepanshu Natani as that is much simpler than trying this with the JSON edits.  Thanks!
