Dear gurus
I am trying to send a POSTMAN "POST" request to JIRA Service desk to create an incident.
The following pictures show my settings and the permission issue I face. I have NO idea what I am doing wrong.
Is the token correctly implemented? I know the token id is correct but not sure if the email address can be part of the token variable {{Jira_token}}
I have checked permissions as you can see and seems to be ok. I am on the free plan and using the same user to create an incident.
Where do I go wrong??
Hi @R P ,
Please scroll down the view from the permission helper, in the left bottom of the message there should be a link to show failed conditions - please expand that.
Also double check if you can create request in this project as used user: from Jira and from the Customer portal side (if its available for future customers)
Thanks @Lucas Modzelewski _Lumo_
I just happen to solve the problem.
In Postman the credentials needed to be set to Basic Auth
and then:
That was all! I was under the impression that the Basic Authentication wasn't allowed at all and it needed to be Token.
All good now!
