Restrict issue links types in specific issue types
James Brown
October 26, 2017
I have many issue link types to fulfill traceability requirements for documentation.
I would like to restrict link types for outgoing and incoming links from specific issue types to specific issue types.
Is this possible through a workflow status property?
Lenard Lee
November 19, 2017
Hi James,
I'm afraid to say that I think the native JIRA does not have this feature.
Some similar feature requests in the past would be
1. JRASERVER-36494
2. JRASERVER-16745 (This seems to match your use case)
3. JRASERVER-9634
At the moment, I found a plugin, Extended Schemes for JIRA  which I think could help. In its description, it states that the plugin could, among others, do the following:
1. Control what Link Types are availabe for each scheme.
2. Disable linking for specific Issue Types or whole Projects.
Best regards,
Lenard
