Since 24h, the system is in scheduled maintenance, which is not in line with the system status. This is what the page shows:
It looks that your specific site is under maintenance not whole Cloud site that is way it is not accurate to status page however 24h is a pretty long time.. I think Support might know more information when it would end so feel free to use contact Support button.
Hi @Philip Moncke ,
Are you operating in any areas listed for maintenance during March (Singapore and Northern California)?
On an additional note/question - have you maybe been using product trials which may have expired? There's a known issue that if the product expires within the nightly maintenance window, you'll probably get stuck with a maintenance warning forever (not sure if this was fixed meanwhile: CLOUD-12117: Products that expire during a maintenance window do not indicate to end users that they are expired
Tobi
