Using issue in linkedIssues using JQL
Geetha
I am looking to create
issue in linkedIssues(JIRA-123,JIRA-234,JIRA-245)  for example ,  currently I can do this by
issue in linkedIssues(JIRA-123) OR issue in linkedIssues(JIRA-234) OR ..
Is there another function or correct syntax that can help me pull out all the issues under these epics .
Bhushan Nagaraj
September 21, 2017
Hi vgp,
Highly recommend taking a look at the JQL Functions provided by ScriptRunner if you already have the add-on installed. Documentation is available at https://scriptrunner.adaptavist.com/latest/jira/jql-functions.html#_issuesinepics
Hope that helps.
Cheers
Bhushan
Geetha
Thanks Bhushan, not familiar with script runner yet. I was wondering if there was any simple JQL syntax to do that.
-Geetha
