When i move issue to done not mark as done?
Kalpaj Kuber Parmaj September 4, 2022
When we are moving issues to done state issues not marked as done
5 votes
Rik de Valk
Hi @Kalpaj Kuber Parmaj ,
There's not a lot of information in your question that can help us figure out what is exactly going on.
But some common problems that occur in this area are:
  1. Workflow: The resolution of an issue is not being set on the status transition to Done. You can add a post function to this transition that sets the field Resolution to Done. Or you add a screen to the transition where the user can choose a resolution
  2. Board: the Done status is not mapped to the last (right-most) column in the board. A Board in Jira will only consider the last column as 'done' in its reporting statistics.
For the first (and most common) cause, you can review this documentation: https://confluence.atlassian.com/cloudkb/best-practices-on-using-the-resolution-field-968660796.html
I hope that helps. If not, maybe you can give some more details about the situation.
Have a nice day!
Fabio Racobaldo _Catworkx_
an issue needs to have a resolution set in order to be considered done.
Fabio
Kalpaj Kuber Parmaj September 12, 2022
