X-Ray Test Repository at project level
amit kshatriya
July 15, 2019
Can test repository and test set both be enabled globally and different teams can choose if they want to use test set or repository in their respective project?
We already have X-ray that teams are using with test set but with the new feature of repository coming in we want to enable it too and give teams options to use either test set or repository, is that possible or there can only be one enabled globally?
José Domingues _Xray_
Hi Amit,
Yes, it is possible to have both the test repository and the test set on the same project. :)
Best regards,
Xray Team
amit kshatriya
July 31, 2019
Do you have any documentation on how to go about doing it?
Hi Amit,
Yes, you can find that information in this section: https://confluence.xpand-it.com/display/public/XRAY/Organizing
Best regards,
Xray Team
