is it possible to not allow a workflow transition until a date specified by a custom field?
Andrea Melde October 26, 2016
Fidel Castro
October 26, 2016
You can do it using "Boolean condition / validator with math, date-time or text-string terms" from JIRA Workflow Toolbox with the following boolean expression:
{00057} > {nnnnn}
replacing nnnnn with field code of your Date Picker custom field.
Note that {00057} is code for numeric value of Current date and time virtual field.
@Fidel Castro Armario
Will this plug-in update the assignee to a custom user picker field based on a post-function transition?
Fidel Castro
October 26, 2016
Yes, you can do it using "Copy a parsed text to a field" post-function with the following configuration:
  • Target field: Assignee
  • Parsing mode: basic
  • Text to be parsed...:
    %{nnnnn}
replacing nnnnn with the field code of User Picker custom field.
