project + labels jql not returning expected results
Farah NAILI June 16, 2025
Hi
I have this query:
project = XXX and labels in(INC23)
or this query
project = XXX and labels = INC23
neither return any result
however
i do have a ticket in that project with that specific label : XXX-5409
it's driving me nuts
I have run a full reindexation of the system after creation and last update of that ticket... to no avail...
I'm in jira data center, Jira Software 10.3.6
I have all the permissions required to see the issue and the original problem that brought me to this symptom was that i was trying to figure out why i couldnt see expected issues from that project on a board, and then a "plan (advanced roadmap)....
help pwease ?
pawarsachin84
Hello Farah,
Labels in Jira are dynamic tags that you can add to issues to categorize and track them more flexibly.
Is Labels are added via automation/API/scripted fields/plugins?
1. Just in case you can try different JQL to check like
issuekey = XXX-5409
check if above returns issue.
issuekey = XXX-5409 AND labels = INC23
now check if above returns issue.
If not, that confirms a label field indexing problem.
2. To solve this you can try basic simple steps.
You can re-add the label to the mentioned issue
Go to issue XXX-5409 → Edit → Remove label INC23 → Save.
Edit again → Re-add INC23 manually → Save.
NOTE - make sure you are adding correct label to the issue. For eg: INC23 or INC-23 or INC_23 whichever format is correct.
Then try your JQL again -
Project = ABC AND labels = INC23
In above JQL you need to use your project name or key instead of ABC
Farah NAILI June 19, 2025
right!
so searching for the issue did return the expected result
searching for the issue AND label did not
deleting and adding the label from the issue view did not change anything
BUT through deleting from view issue screen THEN clic "edit", add label, save
now the search returns the issue.
thanks @pawarsachin84 !
still a freak bug that, I'm wondering how many more issues' labels are not indexed right???
when i run a full re-indexation, does it not index labels?
Like pawarsachin84 likes this
