"Project is Required" when providing a proper project key
Andrew Zibuda
I am seeing an error when trying to create issue via REST API:
POST request to /rest/api/2/issue returned an error code: status: 400 - Bad Request
body: {"errorMessages":[],"errors":{"project":"project is required"}}
With this request:
 post("/rest/api/2/issue")
.header("Content-Type", "application/json")
.body([
fields: [
summary: newIssue.fields.summary,
customfield_10008: issue.key,
assignee: [
key: newIssue.fields.assignee.key,
cutomfield_10201: newIssue.fields.customfield_10201,
description: newIssue.fields.description,
project:[
key: issue.fields.project.key]
.asString()
This exact same format for a POST including the project key works perfectly in a different POST that creates an Epic. This one is for a story but that shouldn't change anything. Not sure if this is a bug or what.
Nagarjuna Guntupalle
June 14, 2019
Is this fixed, I am stuck at same error?
Gonchik Tsymzhitov
Hi!
Looks like it is typo,
let's try this format
"project": [
"id": issue.fields.project.id ],
 instead of as array
Gonchik Tsymzhitov
Andrew Zibuda
That is the current format. Using ID field results in same error.
