I am getting the following errors during a re-index of the system with Jira 6.3.1.
I can't find anything related to the error - userKey should not be null!
here are the complete errors in the logs -
2014-08-11 15:35:54,868 IssueIndexer:thread-3 ERROR ahughes 933x5998x1 1k1hgkv 1.1.1.1 /secure/admin/IndexReIndex.jspa [onresolve.scriptrunner.customfield.GroovyCustomField] userKey should not be null!
com.atlassian.jira.util.dbc.Assertions$NullArgumentException: userKey should not be null!
at com.atlassian.jira.util.dbc.Assertions.notNull(Assertions.java:29)
at com.atlassian.jira.user.DefaultUserPropertyManager.getPropertySetForUserKey(DefaultUserPropertyManager.java:44)
at com.atlassian.jira.user.DefaultUserPropertyManager.getPropertySet(DefaultUserPropertyManager.java:38)
at com.atlassian.jira.user.UserPropertyManager$getPropertySet$1.call(Unknown Source)
at Script2.run(Script2.groovy:11)
2014-08-11 15:35:54,875 IssueIndexer:thread-3 ERROR ahughes 933x5998x1 1k1hgkv 1.1.1.1 /secure/admin/IndexReIndex.jspa [onresolve.scriptrunner.customfield.GroovyCustomField] userKey should not be null!
at Script10.run(Script10.groovy:11)
2014-08-11 15:35:54,918 IssueIndexer:thread-3 ERROR ahughes 933x5998x1 1k1hgkv 1.1.1.1 /secure/admin/IndexReIndex.jspa [onresolve.scriptrunner.customfield.GroovyCustomField] userKey should not be null!
at Script24.run(Script24.groovy:11)
2014-08-11 15:35:55,493 IssueIndexer:thread-1 ERROR ahughes 933x5998x1 1k1hgkv 1.1.1.1 /secure/admin/IndexReIndex.jspa [onresolve.scriptrunner.customfield.GroovyCustomField] userKey should not be null!
2014-08-11 15:35:55,498 IssueIndexer:thread-1 ERROR ahughes 933x5998x1 1k1hgkv 1.1.1.1 /secure/admin/IndexReIndex.jspa [onresolve.scriptrunner.customfield.GroovyCustomField] userKey should not be null!
2014-08-11 15:35:55,524 IssueIndexer:thread-1 ERROR ahughes 933x5998x1 1k1hgkv 1.1.1.1 /secure/admin/IndexReIndex.jspa [onresolve.scriptrunner.customfield.GroovyCustomField] userKey should not be null!
2014-08-11 15:43:39,472 IssueIndexer:thread-6 ERROR ahughes 933x5998x1 1k1hgkv 1.1.1.1 /secure/admin/IndexReIndex.jspa [onresolve.scriptrunner.customfield.GroovyCustomField] userKey should not be null!
2014-08-11 15:43:39,484 IssueIndexer:thread-6 ERROR ahughes 933x5998x1 1k1hgkv 1.1.1.1 /secure/admin/IndexReIndex.jspa [onresolve.scriptrunner.customfield.GroovyCustomField] userKey should not be null!
2014-08-11 15:43:39,515 IssueIndexer:thread-6 ERROR ahughes 933x5998x1 1k1hgkv 1.1.1.1 /secure/admin/IndexReIndex.jspa [onresolve.scriptrunner.customfield.GroovyCustomField] userKey should not be null!
I found out what the issue was - We have a custom user field named Customer and the scripted reads the public user properties from these users. Several entries had the users login I.D. set instead of the full name.
example Customer: asmith
Should have been set to Customer: Smith, Abby
Once it was changed to the full name, the errors are gone
The most recent release has better and more concise error messages for script field failures.
For the second field (Read and Display User Properties on Main Issues)
replace
propValue = userPropertyManager.getPropertySet(dirUser)?.getString('jira.meta.'+propKey);
with
if (null != dirUser)
and try to reindex again
if that didn't help:
try {
} catch (Exception e) {
//ignore nullpointer
Most possible you've deleted some user that was used in configuration of the script custom field. You should review your existing script field and check if they contain proper data. Do you use those fields at all? Please check https://jamieechlin.atlassian.net/wiki/display/GRV/Scripted+Fieldsfor details
3.) Display Previous Issue Key Number
import com.atlassian.jira.ComponentManager
def componentManager = ComponentManager.getInstance()
def changeHistoryManager = componentManager.getChangeHistoryManager()
x = changeHistoryManager.getPreviousIssueKeys(issue.id)
if (x.join(' ') == "") {
return null
return x.join(' ')
4.) Display Parent Issue Custom Numeric Field on Sub-tasks
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.component.ComponentAccessor;
field = ComponentAccessor.getCustomFieldManager().getCustomFieldObject('customfield_13000')
if (issue.isSubTask())
def abc456 = issue.getParentObject().getCustomFieldValue(field);
return abc456
return null;
5.) Display Parent Issue Custom Date field on Sub-Tasks
field = ComponentAccessor.getCustomFieldManager().getCustomFieldObject('customfield_11401')
return abc456
return null;
I haven't deleted any users used in the configuration.
Here are the scripted fields setup -
1.) Display Parent Issue Attachments on Sub-tasks
2.) Read and Display User Properties on Main Issues
And here is the code for each -
1) Display Parent Issue Attachments on Sub-tasks
import com.atlassian.jira.issue.attachment.Attachment;
String s = "";
if(null != issue.parentObject)
for(Attachment att : issue.parentObject.attachments)
s = s +"<a href=\"" + ComponentManager.getInstance().getApplicationProperties().getString("jira.baseurl")+
"/secure/attachment/"+att.id+"/"+att.filename+"\">"+att.filename+"</a>" + "<br>";
return s;
import com.atlassian.jira.user.ApplicationUsers;
import com.atlassian.crowd.embedded.api.User;
import com.atlassian.jira.user.UserPropertyManager;
UserPropertyManager userPropertyManager = ComponentAccessor.getUserPropertyManager();
String propKey = "public Location";
String propValue = null;
def u = getCustomFieldValue('Customer')
if (u) {
def dirUser = ApplicationUsers.toDirectoryUser(u)
return propValue;
As Alexey said, it looks like the problem is that a user has been renamed.
What version of the plugin are you using?
It needs to have better error messages than that, I'll look into it.
