Hi everyone,
I'm actually debugging an instance looking at the logs i find that one of the script on the instance generate most of my errors but i cant figure why ...
The error in the log look the same everytime :
2020-07-07 12:54:13,535 https-jsse-nio-8443-exec-206 ERROR afcaire 774x1732710x1 1n7aouf 10.33.117.20,10.33.97.14 /rest/scriptrunner/behaviours/latest/runvalidator.json [c.o.jira.behaviours.BehaviourManagerImpl] *************************************************************************************
2020-07-07 12:54:13,537 https-jsse-nio-8443-exec-206 ERROR user 774x1732710x1 1n7aouf 10.33.117.20,10.33.97.14 /rest/scriptrunner/behaviours/latest/runvalidator.json [c.o.jira.behaviours.BehaviourManagerImpl]
Script function failed on issue: (create issue) project/issuetype: SUPTOOL/Bug, user: user, fieldId: customfield_13575, file: subtack_copy_product.groovy
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'null' with class 'null' to class 'long'. Try 'java.lang.Long' instead
at subtack_copy_product.run(subtack_copy_product.groovy:11)
So i find the script and i can't figure out what's going on.
Here's the script:
import com.atlassian.jira.component.ComponentAccessor;
// 3 lines needed to use a groovy file for fieldbehavior
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
// Get all interesting fields
def type = getFieldById("issuetype").getValue()
def parentId = getFieldById("parentIssueId").getValue() as long
def product = getFieldByName("Product")
// If it is a sub-task, and product is not yet set
if (type == "10003" && product.getValue() == null) {
// Get the parent issue
MutableIssue parentIssue = ComponentAccessor.getIssueManager().getIssueObject(parentId)
//Get the value of the product field
def parentProduct = parentIssue.getCustomFieldValue(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Product"))
// Set the product field to the same value as the parent
product.setFormValue(parentProduct.getOptionId())
I would appreciate à lot a bit on help on this one !
Thanks a lot !
Florian
I'd expect this to fail if it is applied to issues that are not sub-task types. These won't have a parentIssueID, so line 11 is coming back "null"
Thx a lot. I think i just fix the problem by mooving the def in the if:
//def parentId if the ticket is actually a sub task for avoiding null value
It'll go in test tomorow :)
