Best Power Ups for project reporting and dashboards
Lora Abu Rashed
October 8, 2017
Hello all,
I just started using Trello for managing my projects. What is the best power up that I can use to create reports and on line dashboards for my programme / project.
I may need to export the reports to pdf or word format.
Thanks in advance,
Lora
Sami Linnanvuo _Screenful_
For visual dashboards, I suggest you to also take a look at the Screenful Power-Up
Francis Peixoto
October 19, 2017
I can't advocate for specific powerups, but I've heard Corello (Agile) and TeamGantt (Waterfall) have positive reviews so far.
