Hola a todos!
alguien ha encontrado alguna forma o apps, que permita calcular el porcentaje de avance real de un proyecto (para todo el proyecto), vs el porcentaje esperado?
He tratado con Big Picture y Road Maps, y no he encontrado solución a mi necesidad.
Saludos,/
Hello @Ansar Rezaei
I am really happy that you find my answer useful.
There is no ETA for this feature yet. There are many requests in our backlog, and some of them do have a very high priority at the moment. However, I recommend following the request status and its Customer Rank.
Best,
Anna
SoftwarePlant Support
Thanks for your clarification.
Do you have any estimate about when you deliver it?
Hello Gustavo
ad Has anyone found a way or apps that allow us to calculate the percentage of real progress of a project (for the entire project), vs the expected percentage?
A couple of ways to track the progress of a project in BigPicture are discussed here: Progress tracking in BigPicture.
As a rule of thumb, whenever you deal with a progress bar in BigPicture, be it the portfolio level, or a task level, the green, wide bar represents the actual progress, while the blue, narrow bar directly beneath the green one, stands for the expected progress (at that particular moment in time).
Have a look at the below screen capture. The 'Hire an architect' task has the 52% actual progress vs. the 100% expected progress.
Hi @Ansar Rezaei ,
Expected progress in BigPicture 8 does not work at the moment. We are sorry for the inconvenience. However, we are continuously working on BigPicture improvement, and we are aware that our clients need this functionality.
We plan to add a new feature: Expected Progress displayed in the column as a lozenge (like Time Tracking columns).
You can follow work progress in the feature request ticket: ONE-28625. Please note that it is best to open it in the incognito tab of your browser.
Best,
Anna
Hi @Marcin Geb _SoftwarePlant_
Does expected progress works in Big Picture 8?
I can't find any documentation that helps me to calculate this progress correctly. according to the attached picture, this progress calculated equal to 100% for all issues in my plan. Could you help me with that?
