Advanced Roadmaps and links between items
Patrick Wright August 18, 2020
Hi
I've been using Jira Advanced Roadmaps in the new interface for a month or two. Am now starting to experiment more with scheduling and dependencies.
From my experiments, it seems that JAR only acknowledges and displays the "blocks/is blocked by" links between two items. There are many alternative link types, for example, "has to be done before" or "has to be finished together with", which are in some ways more descriptive than "blocks". However, as far as I can tell, only "block" links are shown on JAR as linking two issues.
Is it possible to show link types other than "blocks" on JAR?
Which link types affect how the auto-scheduler works?
Thanks!
Thomas
August 18, 2020
Hi @Patrick Wright
The 'Blocks/is blocked by' issue link is the default one being considered by Advanced Roadmaps, but it is possible to add/remove issue link types to be loaded and considered as dependencies by Advanced Roadmaps.
Documentation on this: https://confluence.atlassian.com/advancedroadmapsserver/configuring-issue-dependencies-802170496.html
Thomas
Thanks, Thomas, that helps!
Rob Horan
November 16, 2020
So just to be clear:
  • Advanced Roadmaps only offers one type (blocks) by default
  • You can create custom dependency types
  • You can select from multiple dependency types in an order if your choosing
Is that right?
Like ilia kassianenko likes this
Jeret Shuck
Looking to do something similar here. Does anyone know I can add additional dependency types when using Jira cloud?
