Hello, I recently setup an Advanced Roadmap for our JIRA projects but I'm the only one who can edit it. All other team members are getting the "Read Only" icon and cannot edit the plan. Is there a way to make the Roadmap plan accessible (Read/Write/Modify) to everyone?
Thank you for your help on this. I'll need to contact the JIRA Admin to help with this. How does the Advanced Roadmap User come into play. It looks like I'm unable to select that in the permissions field in the Roadmap plan Settings area.
Advanced Roadmap User is just a permission level. Probably the most popular one as it allows Create, View and Edit of plans.
Go to the configuration (left side of the Timeline) then click permissions to add persons you want to have "Edit" access. If you don't have access to configuration/setup, please reach out Jira Admins. I'm sure they will help you. Hope it helps you. Have a nice day!
Hi @Stephen Cowden
Yes, go to Plans/settings/Advanced Roadmaps permissions (If you can't get there, you'll need to discuss with your Jira Admin folk), from there you can configure which groups can do what.
