Can I use put different project types in 1 plan in portfolio?
Edlene Cervantes
September 25, 2019
I have several projects running that I need to view in 1 plan. 1 is using Kanban (business) and the other is Scrum (Software). Can I put them in 1 plan for me to track them together?
Ste Wright
Hi @Edlene Cervantes
This should be fine - when creating a project you choose a "template" - usually either Kanban or Scrum - but that does not make them different.
If the concern is different estimates, you can have a mix of points and time-based estimates, allowing for conversation between the two.
The instructions to do this can be found here.
Ste
