How to link a Test Case to a Jira Card
Vinu Charuvil Rajan March 14, 2024
I would like to link/add a test case to the Jira Card through the Jira API/Zephyr API? Is there a Zephyr API endpoint that I can use which can take a Jira Issue Id or the Key and the Test Case Case Id/Key add it to the Jira Card?
I use the below endpoints base url:
Zephyr Scale : https://api.zephyrscale.smartbear.com/v2/
Atlassian : https://<<xxx>>atlassian.net/rest/api/3/
Andy Barbet
March 20, 2024
I can confirm that there is no endpoint in the Zephyr Scale API to do what you're looking for.  I don't think there is any API integration for Scale on the Jira side either - not to my knowledge.
