java.lang.LinkageError: loader constraint violation: when resolving method "com.querydsl.sql.SQLQueryFactory.<init>(Lcom/querydsl/sql/Configuration;Ljavax/inject/Provider;)V" the class loader (instance of org/apache/felix/framework/BundleWiringImpl$BundleClassLoader) of the current class, com/atlassian/rm/common/bridges/jira/persistence/JiraDatabaseProviderBridge74, and the class loader (instance of org/apache/felix/framework/BundleWiringImpl$BundleClassLoader) for the method's defining class, com/querydsl/sql/SQLQueryFactory, have different Class objects for the type javax/inject/Provider used in the signature
at com.atlassian.rm.common.bridges.jira.persistence.JiraDatabaseProviderBridge74.execute:52
at com.atlassian.rm.common.persistence.env.JiraDatabaseProvider.execute:36
at com.atlassian.rm.common.persistence.DefaultDatabaseProvider.run:26
at com.atlassian.rm.jpo.core.plan.sql.QueryDslPlanPersistence.getAllPlans:275
at com.atlassian.rm.jpo.core.plan.api.DefaultPlanListingService.getAllPlans:62
at com.atlassian.rm.jpo.rest.service.program.ProgramRestEndpoint.getProgramList:118
at sun.reflect.NativeMethodAccessorImpl.invoke0:-2
at sun.reflect.NativeMethodAccessorImpl.invoke:62
at sun.reflect.DelegatingMethodAccessorImpl.invoke:43
at java.lang.reflect.Method.invoke:498
at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper$ResponseOutInvoker$1.invoke:192
at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper$1.intercept:83
at com.atlassian.plugins.rest.common.interceptor.impl.DefaultMethodInvocation.invoke:53
at com.atlassian.plugins.rest.common.expand.interceptor.ExpandInterceptor.intercept:41
at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper.invokeMethodWithInterceptors:110
at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper$ResponseOutInvoker._dispatch:190
at com.sun.jersey.server.impl.model.method.dispatch.ResourceJavaMethodDispatcher.dispatch:75
at com.atlassian.rm.common.rest.scope.RequestOperationScopeDispatcher.dispatch:25
at
[...], Removed, Ticket Description was too long.
=== Request ===
URL: /rest/jpo/1.0/programs/list?_=1564270211181
Type: GET
Status: 500
Data: undefined
=== Client Info ===
User agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.13; rv:68.0) Gecko/20100101 Firefox/68.0
Local time: Sun Jul 28 2019 01:30:24 GMT+0200 (Mitteleuropäische Sommerzeit)
=== Plugin Info ===
Plugin build: 3.6.0
=== System Info ===
Jira Title: ILCAI Jira
Jira Version: 8.0.2
Agile Version: 8.0.0-DAILY20190215023029
Hi there Philip, I did some scouring around and found this bug which matches the error message you are seeing almost exactly : JPOSERVER-2511.
The report states that this happens if a Timetracker add-on was installed before installing Portfolio. Is this what happened in your instance as well?
If it is, you may want to try out the workaround that was provided in the bug ticket (there are some jar file downloads involved, so I can't just paste it here). Let me know how it goes!
Yes, that was exactly the case.
What helped me was:
- Stop Jira
- Remove the corrupt dependency plugin
- Restart Jira
Thank you very much!
