I find Advanced Roadmaps interface a good way for creating new backlog items. But on the other hand I like using templates for applying definition of ready in description, filling out several other fields. Is it possible to create new backlog items this way using templates? I know I can apply templates to individual items later but this doesn't really scale up.
Hi Łukasz,
Check out this short video on youtube showing how to integrate Advanced Roadmaps with Issue Templates for Jira, maybe you will get inspired.
Cheers!
I'm sure you can create some automation so that when issues are created then it's pre-populated with some information or a 'template' of sorts. This is something that we've done in the past.
Jacob
