Is it possible to diseable to Create Issue in Jira Advanced Road
Laurent CARPIN
February 12, 2024
+ Create Issue
I like to know if it is possible to avoid creating Issue in the Jira Plan (Advanced RoadMap ) - Data Center
The context and Default Value doesn't work
Simon Carroll February 12, 2024
You should be able to create a filter and then create a plan from that filter
Laurent CARPIN
February 12, 2024
Hi, I do not think it'a answer to my question - Avoid cerate an issue from Jira Plan
SERVER
