×If a JIRA AR plan has been deleted, is it possible to recover / restore this plan?
Unfortunately, just like with other objects in Jira software, once it is deleted, it cannot be restored. Unless you rollback the entire DB backend from your previous back-up, but this means that all changes in the system since the last backup will be lost.
You only option is to recreate the plan manually and start fresh.
Hope this helps. Sorry.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
Thanks for the reply Joseph Chung Yin. I expected that would be the case, but asked just in case there was an alternative workaround.
You are welcome. If my statement addressed your ask, please click on "Accept Answer" when you have a chance.
Best, Joseph
Is there a solution yet on this?
Welcome to the community. In AR for Jira plan, once an object is deleted, it is deleted for good. No solution at this time to restore the deleted plan.
Best, Joseph
