Is there a way to show dependencies from outside of the plan in the Dependencies Report view?
Doug Snyder November 19, 2021
I have created a plan that contains a project work issue with a dependency on a work issue in a different project.  That other project is not included in the plan I have created.  The dependency was created via the "issue links" capability within the issue.
While I can click on the dependency badge in "Roadmap" view and see the dependency in the "not in this plan" section of the popup, when I switch to the "Dependencies report" view this dependency is not included in the visualization.  Is it possible to do this, or does the "Dependencies" report only show work issues that are part of the plan?
Joseph Chung Yin
@Doug Snyder -
Unfortunately, AR for Jira currently doesn't support "Linked Issue"concept.  Therefore, it will not work for what you tried to accomplished.  It is currently only support issues association via the issue hierarchy relationship setup.
I would recommend you to contact Atlassian Support for further assistance.  I believe there are feature requests on their roadmap already.
Hope this helps.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
Rahul_RVS
Hi @Doug Snyder
If you would be interested in a third party add-on, you can try out our app to view the full Jira Issue Type hierarchy of Linked issues, Portfolio/Advanced Roadmaps, Epics, and Subtasks up to 10 levels.
Agile Tools - Epic Tree, Links Tree and Time in Status
Key features of Links Hierarchy:
  • Hierarchy upto 10 levels deep
  • Progress % on "remaining estimate" or "original estimates"
  • Edit Issue summary, time estimates, story points and assignee on the tree with real time updates in the progress
  • Rolled up percentage completion at all levels
  • Ability to add/remove the columns on the report
Thyago Chiprauski
November 19, 2021
If you create a filter for your plan including the other project it works
@Joseph Chung Yin Thank you so much for the prompt reply!
Joseph Chung Yin
@Doug Snyder -
If my suggestion helped, please click on "Accept answer" when you have a chance.
Best, Joseph
danielle.cooper1
January 2, 2024
Did not work for me. The tasks got added, but not associated with their linked issues.
