Is Advanced Roadmaps for Jira (server/DC) able to import plans from other sources such as MS Project native mpp/mpx, xml, csv, xlsx formats or other similar apps?
I'll just make a quick note on import/export of AR data between Jira instances.
The functionality to import/export as part of a migration or sharing of data is not possible, but there is an outstanding Suggestion ticket requesting this:
In newer versions, there is also an export/share function to export data but it's not for AR import and is more so designed so you can have a ".csv file that you can import into a different program such as Excel, or share your plan with relevant stakeholders in a variety of ways":
Just to add further details,
There are 3 source types for Advanced roadmap, namely
Board,
Project,
Filters.
Reference- https://confluence.atlassian.com/jiraportfolioserver/configuring-issue-sources-935577871.html.
As far as I know, there is no import function available for AR for Jira.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
