Issue hierarchy for Advanced Roadmaps
James Wardle
Hi.
I've set an issue type to be above Epic, as this is how we would like to group Epics. I'm confused why Capability has a 2 against it? Does that have any impact or is the hierarchy purely the order from top to bottom?
Barnali Putatunda
August 22, 2022
Hey James,
This is just to show the hierarchy level from top down. If you create another level on top of Capability, you would get no 3 assigned against it. So, basically issuetype in #2 is parent of issuetype defined in #1, issuetype in #3 is parent of issuetype defined in #2.
It has no other impact.
Barnali
James Wardle
Ah okay, that makes sense now. Thanks for the reply @Barnali Putatunda!
Giacomo August 22, 2022
Hi James,
I'm not sure whether this will match your full use-case but you might want to check out my Collections app, which allows you to create multi-level Issue hierarchies:
https://marketplace.atlassian.com/apps/1228301/collections?hosting=cloud&tab=overview
Giacomo
