Issues decolored in Jira RoadMaps
Javier Lahoz July 6, 2023
Could you, explain, please why from the issue RETO_Milan till the end the issues are decolored?
2 accepted
Joseph Chung Yin
@Javier Lahoz -
You have "filter" applied in the current plan, thus issues that don't fit the filtered criteria will be "gray out" essentially.  If you remove the filter setup, then those issues will be re-enabled.
Best, Joseph
Javier Lahoz July 7, 2023
thanks!
Laurie Sciutti
Hi @Javier Lahoz ~ I believe this is due to a filter applied in the Plan.
