Issuetype Feature above other Standard Issue Types in Hierarchy Level
Armin Rothe
March 11, 2024
is it possible to add a Hierarchy like Epic - Feature - Story (standard Issuetypes) - Sub-Task?
Because I am not able to push a new level with only "Feature" below the "Epic" 2024-03-11_12-12-52.png
Thanks for your support.
Best regards
Armin
Daniel Capizzi
March 12, 2024
Hi @Armin Rothe
In Jira Data Center the best way to achieve an "Epic - Feature - Story" hierarchy is through the flexible terminology settings.
First, use the "Terminology" page under your Administration settings to rename "Epic" to "Feature".
Then, you can create a new Issue Type called "Epic" and use the hierarchy configuration settings to put it the level above your newly renamed "Feature" level.
Hope this helps!
Daniel
Hannes Obweger - JXL for Jira
Hi @Armin Rothe
you can only add additional levels above the epic level. Kindly see this thread for possible ways forward.
Best,
Hannes
